From the laptop in scan mode ? Tia.
We sure need at least our fan to run at high speed via Vehicle Controls! These engines get awfully warm in the staging lanes. I put in a request several months ago and did get a request for my info log and debug.dat. Have not heard anymore from HPT. Apparently it's not that easy with the new controls GM has in the 2017s.
My fan works now! You guys are super great! Thanks to all at HP Tuner for this feature!
You can now turn the ZO6 radiator fans on with HTP Scanner ? Or IC pump ?
The fan Vehicle controls works. I could not find a control for the hx pump. Not sure why we would need that as I'm pretty sure it comes on at a fairly low temperature with the stock tune. According to the file it does not run below 104* so I'm guessing on is just above that.
Which command are you using for the rad fans ? I found a IC pump command. If we can run both at the same time it will kill heat soak and it.
Vehicle Controls. There is an on off for IC pump.
Sorry to bring this up from the dead. Vehicle is a 2018 CTS-V and using scanner the fan controls do nothing, nor does the Boost IC) pump on/off. Should they now or still working on it?
Nothing?
