I'm trying to understand something that I notice is occurring. I run my car at the track so I need it as consistent as possible. I launch from a 2-step, run it in open loop, shut off all KR and have zeroed all the spark modifiers I can find. I have the
What I notice is after I launch and as I go through 1st gear, the spark fluctuates. It goes from 25 down to 22 and back up a few times. If you look at my RPM going through first gear in the log, notice how it starts strong, then dips, then accelerates again into the gear shift? That also seems to correlate with the spark fluctuations that I'm seeing. I'm not 100% sure its' the spark causing the dip in the RPM ramp up, but it feels like it is correlated.
After I shift into 2nd, and after the converter locks, it is fairly steady from that point on.
Take a look at the attached log.
Notice the ramp up at launch for RPM, the dip in acceleration at about 7:03:133 and then starts ramping up again at 7:04:355. Also notice the spark dips throughout that RPM acceleration fall off too.
Any thoughts on what might be causing this?
