13 C63 Error when trying to rear arguement out of range
Trying to read a C63 and keep getting this message then vcm suite doesnt work if I continue or closes when I hit quit
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
at ..(Int64 )
at ..(Int64 )
at ?..(ICollection`1 , Int64 )
at ..( , , IList`1 , IList`1 )
at ..( , IList`1 , IList`1 )
at ...ctor(String , , IList`1 , IList`1 )
at ...ctor( , )
at ...ctor( , )
at ..( , String , String )
at ..(Object , EventArgs )
at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(Event Args e)
at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1648.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Assembly Version: 3.4.89.0
Win32 Version: 3.4.89
CodeBase: file:///C:/Program%20Files%20(x86)/HP%20Tuners/VCM%20Suite/VCM%20Editor.exe
System.Core
Win32 Version: 4.6.1647.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 4.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
C1.Win.C1FlexGrid.4
Assembly Version: 4.6.20142.844
C1.Win.C1Chart3D.4
Assembly Version: 4.0.20142.24286
C1.Win.C1Chart.4
{630da21b-ee3f-442d-b0a9-2e47a4325d30}
Assembly Version: 0.0.0.0
System.Management
Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
