2013 CTS-V
Lvl 5 TH400, Manual reverse valve body.
How can I get Vehucle speed to read on the cluster. Anyway to change the Input from Speed sensor on trans to ABS sensor in hpt?
2013 CTS-V
You need to setup the pcm as a manual, then put the v.s.s directly to the pcm, as per manual pinouts.
It was originally a manual car....
The Th400 doesn't have a vss, looking to get the cluster to read from the Wheel Speed sensors
you can add a speed sensor and reluctor wheel to the 400 I'm running it in my f body on vacation right now so I don't have all the info on what I used but its google searchable I found the 40 tooth reluctor that fit the 400 output shaft and pressed it on and used a tail housing from a mid 90s truck ( I think )
95 z28 with 6.0, 243's milled .030 to about 11:1, ls6 intake and tb, brian tooley stage 3 231/242 617/593 112 lsa , fast/ areomotive fuel system, 1 7/8 tsp longtubes, no cats, turbo 400, 36 lbs GTP injectors
Anyone ever figure this out?
