When at WOT the car will hit the rev limiter on the 2-3 shift. I have set the mph lower and also rpm set point lower. RPM is set to 5400 and speed is set to 55 mph. The car will hit the rev limiter at 6300 and the mph is 73. I can change the shift point and the car still will not shift. I can manually control the shift and the car will shift when commanded. What in the tune am I missing that is not letting the car shift. Attached is the tune and log.
thanks for your help2001_camaro__5_28_17_D.hpt2001_camaro_C.hpl
