Originally Posted by
Weston@HPTuners
I've seen this type of timing drift a few times before with various video & data equipment combinations, enough that it was the main inspiration for adjustable playback speeds in RaceRender 3. This does seem to have gotten better in recent years, but it still comes up from time to time.
Digital clocks often seem to run slightly slow or slightly fast, which becomes apparent over time if there's no system in place to automatically correct them, and that's usually what's happening in these situations. Typically, the hardware clocks are close enough to each other to not create a problem, but occasionally some users see a little drift over the span of a longer project, and very rarely it might be enough to noticeably affect shorter projects. In either case, the adjustable playback speed option should help you solve this issue, as this type of hardware drift should be at a pretty consistent rate. If it's not a consistent drift, or if it goes back and forth, then that's even more rare and may indicate other problems.
