Make sure you do a full read after you upgrade to 3.6.
Agreed... no reason to do a re-read.
Download link in first post seems to be dead, frozen, or just plain not responsive, or is it just me???
Just log into your customer page and use the 3.6 download from there.
Or use the link right on the hptuners.com homepage
Thanks guys. Was able to right click and copy url and then paste in new internet explorer tab. Got it installed now.
Greetings HPT! Thanks for 3.6! Enjoying the improvements. Now that there is FPCM and even CCM tuning.....any chance we will get control of the BCM of a 2017 GMC any time soon? Since ACDelco TDS is not letting us flash USA BCM files into GMs that were originally flashed for the Canada market anymore....
Please!
Please!
Just downloaded 3.6 and wanted to adjust fans to turn on earlier after installing 160 deg thermostat on 2008 Yukon Denali 6.2. The Fans table has only Desired % vs ECT. So, what temp do the fans turn on and off and where to adjust it to make them start earlier?
I did multiply % x2 for the range upto 220 deg. Hope it would help.
2003 Chevy Silverado 4x4 1500 RCSB Stepside, 4L60E, LQ9 427ci, cnc L92 heads, PG's Custom Cam, L92 intake, 90 TB, K&N CAI, PS LT Headers, PS ORY Pipe, 3" Catback with 3" Flowmaster.
Table is attached for Fan Desired % vs ECT.
To my knowledge, without a 2 BAR OS upgrade you can not make the fans turn on any sooner.
160 thermostat is pretty overkill anyway, never seen any issues running around 190 like the factory does.
correct.. you can not change the temps at which the fans operate on that vehicle, can only change the % of power that the fans run at, at the preset temps...
and the stock t-stat is already 187*, no need to change the t-stat to a lower temp one..
06MonteSS
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, Custom paint-matched Bowtie emblems, Custom painted SS emblems, BMR strut tower brace, CAI - Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Bo White Ported/Polished throttle body, Custom DiabLew Tune
Just downloaded and installed 3.6 suite.
Got it. It was simple install. So much so I thought it didn't work.HAHA
Has this not been upgraded in a few months? I keep only downloading 3.6.26. Tried the link in this thread and on my home page, same thing.
correct, we are currently only updating 3.7beta
3.6 is very stable in its current form and we want to keep it that way.
Bill can it possibly be made to where tunes made in 3.7 can be opened in 3.6 - this way when things in 3.7 don't necessarily go according to plan you can open 3.6 and copy over differences into 3.6 and keep trucking?
~Greg Huggins~
Unfortunately not, sorry
With this new update, It says VATS relink?
Now does this require credits to that operating system to do the relink?
Will it VATS relink the Holden VZ V6 E55 to another vehicle if it hasnt been delinked from its programmed VIN?
Also if i install this version will i lose my ability to open/ retune my other vehicles that were modified using V3.2?
Thank you
