Originally Posted by
Blue Bee
Do you have any logs of this? Logging commanded gear, actual gear, output shaft RPM? What all is done to the engine, do you have an idea of power it makes? A couple things that you could maybe try, after doing some logs to verify. Raise the "Trans" max RPMs some more, I see you have for example 1-2 shift at 1725 RPM, which is 6210 engine RPM, you are not leaving much room for it to make that decision (based on a 6500 max) but under TQ management in "vs. gear" they are still set as what I can remember as stock, 560.55 for 1st and 2nd gears, is it possible the TCM is calculating more torque than that and because that's the "max allowed" it's deciding to make the shift no matter the output RPMs...?
And also, why are your TCC apply and release tables all crazy, looks like the converter will never lock?
