Originally Posted by
Blue Bee
Is the trans trying to make the shift but it's slipping? You need to log:commanded gear, actual gear and output shaft RPM to get an idea what's going on. To help with tuning the trans (if the trans is ok) lets take the "sports" table "0" under auto shift speed. The numbers are in output shaft RPM, so in your tune it's gonna shift at 1825 RPM, out of 2nd and into 3rd, 2nd ratio in the trans is 3.143, so 1825 X 3.143=5735 engine RPM, but here's the bitch, you will see that it commands it at that RPM but the shift takes place later, it's not exact. You will see this in the logs watching all the info, so you need to up those numbers in gradual steps and log where it shifts and get it where you need it. Like wise, 3>4 shift shows 2810, 3rd ratio is 2.106, 2.106 X 2810=5917 engine RPM, up it some and see where you land. Another problem is there is no way to log what table the computer is referencing, so I just pick a table modify and copy them all the same, for the numbered tables in each section. Once of course you know which section it's actually using...yea, it's not much fun, time consuming as all hell.
