Results 1 to 2 of 2
Thread: Glider aviaton speed indikator
    Jun 2017
    1
    Hello,
    i'm flying glider planes and are happy to see that variometer is added.
    But its missing a propely speed indicator for aviation. or atleast I dont mangage to configure the guages to my use.
    colorbar on speed indicators in gliders are uauly set up with four colours.
    white (standard ) from zero up to stall speed
    green from stall speed up to speed with full controll trows.
    Yellow from full controll trows upp to maximum alowed flight speed (redline speed)
    red further on.. wich you newer exeed.. usualy :-)
    is this somthing you can look into?
    Thank's
    Ullteppet
    HPT Employee Weston@HPTuners's Avatar
    Jul 2014
    39.735034, -103.894459
    868
    Quote Originally Posted by Ullteppet View Post
    Hello,
    Thank's
    Ullteppet
    Unfortunately, getting 4 colors from our generated gauges isn't presently possible, as there are only 3 configurable color sections: base, color change 1, color change 2. In the case of the presently included Airspeed gauges, those are set to Green, Yellow, and Red.
    But you do have the option of editing or bringing in your own gauge background images, as described under the top "Gauge Images" section of this page: http://RaceRender.com/RR3/docs/HowTo-ComplexGauge.html That's usually how people do it when they want realistic gauge images and/or a deeper level of customization. The catch is that it's then not configurable from RaceRender's Gauge Designer (aside from the needle image overlay), which is why we don't normally distribute gauges like this with the software.
