Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: LS3 (and others) Throttle Mapping for better throttle response- Try this...
  1. #21
    Is anyone else not able to see the photos? very blurry for me. Curious if someone has better luck then I
  2. #22
    Jan 2014
    Australia
    1,977
    its a photobucket thing they started to blur photos for all free accounts to make u purchase one
  3. #23
    7,562
    Well that's definitely the kind of behavior I want to reward by giving them money. I know I'm not normal, but do most people respond well to that kind of extortion? My first impulse is to go find their home office and toss a brick through the window (in reality, all I do is add an Adblock filter for anything containing the string 'photobucket').
  4. #24
    Advanced Tuner IARLLC's Avatar
    Aug 2016
    942
    You are not the only one.
  5. #25
    Apr 2016
    331
    So is the consensus that you wont brick the ecm, but if you do too much you could cause a REP condition? Wish i could see the OPs photos. My charts are based on VSS, with the option to switch it to RPM, which makes more sense to me. Also surprised of the restrictive numbers in there as the throttle doesnt seem restricted. I did zero out the accel rate in first gear on another chart, but I didnt mess with this other chart due to the brick warning.
  6. #26
    Apr 2016
    331
    Here are the charts in question. The area opening rate was changed to 100% in the first 2 columns of 1st gear. That fixed what was more of an annoyance in parking lot maneuvers than anything, driving you would blow right through it with the converter. The other chart is the one with the warning which is why I haven't touched it yet.
    stock throttle area opening rate chart.JPGstock desired throttle area MAP A.JPG
  7. #27
    May 2022
    1
    I am having the same issue with the DD cruise Ctrl surging.. Also my throttle is touchy off Idle... Any way i can adjust this?
