Results 1 to 6 of 6
Thread: LC-2 to MPVI Pro - Need Help
    Mar 2004
    British Columbia
    90
    I've searched for an hour and a half before posting so please no lectures!
    Can't get my LC-2 to read properly on scanner when connecting to pro.
    In scanner, in channel window, I've right clicked, added MPVI Input 1, right clicked, transform, selected LC-2 in both EQ and AFR, always reads at top of the readings, either 1.47 EQ or 22.83 AFR.
    Wideband is temp install only, with yellow wire to Pin 1 on Pro, ground in Pin 5, grounds connected together, both power and ground being connected to power port (cig lighter) with adapter.
    What am I doing wrong? Or is this just Innovate headaches and I should try a different brand?
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    I assume you followed this tutorial?
    https://www.hptuners.com/forum/showt...=innovate+lc-2
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Mar 2004
    British Columbia
    90
    Correct, I haven't tried to user define the formula because I don't know what to input, but I've tried the preselectable LC-2 and others but still have this issue. I assume its a wiring issue but I don't know what's gone wrong. Using the yellow wire sends a 0-5v input which I believe is right but the brown wire was no better
    Feb 2006
    PAC NWest
    396
    Can you just connect it with USB?
    Quote Originally Posted by gottogo View Post
    Using USB is much easier than messing around with the analog inputs...
    Tuner in Training luke's Avatar
    May 2014
    PERTH WA
    49
    Have you gone into the logworks programer software and make both the analog out tabs 1 and 2 values the same? I was having a similar issue until I read doing this would help and it did
    0.14 volt at lambda 0.5
    5 volt at lambda 1.52
    try using these numbers in both tabs and see how you go??
    I use serial to usb input with the scanner
