I've searched for an hour and a half before posting so please no lectures!
Can't get my LC-2 to read properly on scanner when connecting to pro.
In scanner, in channel window, I've right clicked, added MPVI Input 1, right clicked, transform, selected LC-2 in both EQ and AFR, always reads at top of the readings, either 1.47 EQ or 22.83 AFR.
Wideband is temp install only, with yellow wire to Pin 1 on Pro, ground in Pin 5, grounds connected together, both power and ground being connected to power port (cig lighter) with adapter.
What am I doing wrong? Or is this just Innovate headaches and I should try a different brand?
