I am working on a small tune for a '12 6.7. I was trying to plug my numbers into the timing calculator but it is using different values toward desired fuel pressure. My tables are using Torque in the Y-axis, where the calculator uses fuel pressure. I figured I am over thinking it or doing something wrong, so what do I need to do? Build a table to reference off the scanner? Thanks for the help.
