Results 1 to 2 of 2
Thread: 2009 Silverado 4l60e to 4l80
    May 2017
    texas
    88
    Trying to get a definitive answer on what is needed tune and electrically to swap over to a 4l80 due to the tfp switch, 3-2 downshift solenoid delete and the internal mode switch. My plan is to wire my t42 over to a 2009 express van with a 4l80 and run the trans segment from it as well. Would this work as far as running the 4l80?
    May 2006
    Seattle, WA
    539
    If the Express TCM 80E OS matches your Silverado TCM 60E OS, just seg swap the Express Transmission and Transmission Diagnostics over.
    If it doesnt match, you can either rewire your existing 60E OS to run the 80E or start with how a 07 80E TCM tune looks and copy the differences over. HPT has the bit values exposed to change the mode switch, I've never had to use them but might be work looking into.
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
