Originally Posted by
Weston@HPTuners
Yes, there are plans to overhaul this with some enhanced graphics and new capabilities, however I should mention that all of the data overlays you listed except for estimated brake are already possible within the current app.
Perhaps I need to revisit the stock overlay template again. My initial test did not have the ODB2 connected and made the assumption since the gauge wasn't present in the overlay it wasn't available.
RaceRender has the capability where you can add a "Peak+Base Speed" banner display to show straights and corner speeds, and also a similar display for peak cornering G-forces... The same type of numbers you'll see in TrackAddict's lap detail screen when in Speed mode or G-Force mode. It's not yet planned if these will be added to TrackAddict's video overlays as well, but in the meantime you can often improve RaceRender's performance on your computer by using smaller video input and output resolutions / frame rates, reducing the Picture Scaling Quality, and using the latest version of Windows or MacOS. Ultimately, it comes down to the performance of your computer, and your project setup, but 1080p30 is usually pretty manageable on most systems these days.
Thank you for the insight into the banner will investigate.
While we don't have any near-future plans to bring videos from external cameras into our TrackAddict app (limited storage space, slow transfer speeds, and other practicality concerns; this need is much better served with RaceRender on a computer), we are continually expanding TrackAddict's lap and data analysis capabilities. What types of analysis and displays are you currently using Circuit Tools for?
