I have had this issue randomly, it started on my old LQ4 and I made some KR Global gain adjustments (went from .9 to 1.4) and it went away. Now I have a whole new engine and trans and its doing it again. Now its by no means stock. It all started when I put the current ID1000 injectors in. As soon as it enters PE it will max the KR until I let off and it exits. I know its false, it acts like its picking up the injector noise or if possible the fuel spray on the valve. IDK. Setup is as follows
370CI, Forged crank and pistons, Billet rods, TVS2300, TEA TFS 225 heads, 230/242 115 cam and Solid Engine Mounts.
I could always adjust it a bit more I just wonder if anyone has seen this with Injectors, the injectors and the Blower are the only thing in common with the old motor.
If I get into it fairly quick it doesn't do it.
Ive ran race gas and done all the normal stuff to ensure its not real, it 100% follows PE. Then Ill drive a bit and it will quit, then come back.
