Results 1 to 5 of 5
Thread: 2012 Coyote mustang dyno pulls
    Oct 2015
    3
    I have a 2012 car with a nitrous system i'm tuning, I usually do LS cars or 2013 and up coyote cars with select shift. Any insight if there is a was to hold gears on the dyno with the Coyote cars as you can with the New gm vehicles? Thanks in advance.
    Sep 2010
    872
    The scanner does not have an option to lock you in gear for a dyno, you could make a tune and change the downshift RPM and MPH to something that won't let it downshift when you go WOT in 4th, that way you can get the full pull
    Tuner kleistang's Avatar
    Jan 2017
    Miami, FL
    82
    Is this what you need ?
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Test lock in gear is the only way I've found for it not to down shift everytime you go wot with a 11-12 car. Also set the converter to lock at like 40mph.
    Oct 2015
    3
    Awesome thanks guys, I'll try for the converter and the lock in gear on some N/A pulls before I spray it. Thank you!
