2012 Coyote mustang dyno pulls
I have a 2012 car with a nitrous system i'm tuning, I usually do LS cars or 2013 and up coyote cars with select shift. Any insight if there is a was to hold gears on the dyno with the Coyote cars as you can with the New gm vehicles? Thanks in advance.
The scanner does not have an option to lock you in gear for a dyno, you could make a tune and change the downshift RPM and MPH to something that won't let it downshift when you go WOT in 4th, that way you can get the full pull
Is this what you need ?
Test lock in gear is the only way I've found for it not to down shift everytime you go wot with a 11-12 car. Also set the converter to lock at like 40mph.
Awesome thanks guys, I'll try for the converter and the lock in gear on some N/A pulls before I spray it. Thank you!
