Is it normal I can't see notting than 4 or 5 sae parameter with 03 cummins 250hp with scanner.
Have you reflashed the truck with the extended logging parameter patch? Have you tried to add channels? Have you tried to re-connect it? Sometimes not all parameters get detected.
2003 305/555 QCSB Cummins
Piston/rod/sleeve/fire ring/dual CP3/300 overs
Super Stick NV5600
S366/S480
Yes to all your question
