Hi All,
As I stated, I am new to tuning and am loving the challenge of learning. But I am still a bit shy of making changes without the collective experts weighing in and ensuring I don't do anything too stupid...
OK, so the engine has a cam, and stroked crank, MSD instake, Long tube Headers. It was originally tuned in Denver CO, and is now in sunny AZ. I am sure stuff needs to be fine tuned and I am working towards that. My big issue is that the motor stalls on low RPM driving then clutch in on stops. the motor will lope to about 200 or 300 rpm then attempt to come up, but then stall. It does not happen if I am coming to a stop from driving at speed - IE, if I exit a freeway and clutch while cruising it will hold idle. slow speed to clutch will kill it. This is generally with AC on, but does it sometimes when AC is off.
I am attaching Tune and Logs. I am also attaching Innovate log for idle AFR. I am not sure if the logging I have in my HP Tuner setup is working as expected.
I would sincerely appreciate any help you can offer, and thank you for your time in advance.
-- Eric
