Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Copperhead Calibration Only Reflashing now in VCM Suite 3.7 Beta
    Oct 2007
    Crawfordville, FL
    2,410
    Several customers have contacted us about adding the ability to do calibration only reflashes on the Copperhead to save time.
    As of VCM Suite 3.7.110, this is now the default method for flashing. You must first disable the P0605 DTC from the DTC list before using this method of reflashing.
    Total time required for a full reflash is 3 minutes, 15 seconds.
    Total time required for a calibration only reflash is 53 seconds.
    If you are changing strategies, or applying an OS Patch (such as the Copperhead limiter patch), you must do a full reflash. Once the strategy has been changed or the patch applied, you can use calibration only.
    Eric Brooks
    HP Tuners, LLC
    May 2016
    1,134
    Thank you. The time saved definitely adds up.
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    Same here. Thank you Eric. That makes things so much easier.
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Sep 2010
    872
    You the real MVP Eric, so we should make sure the first write is a write entire and then after that we can always use write calibration only(unless we are applying a patch of changing strategy)? or can we read the stock file and immediately do just a write calibration only the first time we go to flash the car?
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Noticed the rest of the torque ratio tables were labeled too.
    Sep 2010
    872
    Quote Originally Posted by bbrooks98 View Post
    Wot you are right....wonder what else has been added
    Oct 2011
    Gainesville, VA
    301
    Noticed fuel rail temp compensation too. Yea that labeling fixed my target N hunting issue. It was disabled lol
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Awesome! This will certainly save a lot of time.
    Any chance this will be coming to the TC-1797 Eco?
    You da man Eric!
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    Quote Originally Posted by 96gt4.6 View Post
    You da man Eric!
    As of the latest 3.7, TC-1797 takes ~50 seconds using the same method.
    TC-1767 and Oak1472 have also been updated with 30 and 40 second flash times.
    May 2016
    1,134
    Is there a changelog somewhere for the Beta so I can keep an eye on it to see if anything gets added that I would be interested in? I don't want to miss any little changes that don't get mentioned and could help me write better tunes.
    I can't seem to locate a download for the beta? where can I get 3.7?
    May 2016
    1,134
    Email [email protected] and ask them to add it to your downloads page. Include your interface id
    May 2016
    1,134
    Quote Originally Posted by Jn2 View Post
    2011 Coyote Mustang
    Jan 2013
    Hawaii
    2,101
    The clip/add torque makes more sense with off, look up, intervention prevention, adaptive rather than what it was. I saw a few other switch labels.
    May 2016
    1,134
    Yes. They added some Ecoboost truck stuff too. Started messing with one this morning and saw it. They say the HSPI and LSPI tables are based on octane modifier like I have always thought would make sense rather than what one of the major teaching sources said they are in relation to. I've been keeping my high where I want it and dropping 0.05 or so to nominal then more to low so it works out.
    Sep 2010
    872
    I have a questiona bout the "disable P0605" part of the instructions.
    I tried to use "write calibration" last night on a Saleen I was tuning and it gave me a window to make sure the code was disabled, I double checked and the code was set to "no error reported", but to be safe I made sure the drop down list didn't also have a "disabled" option. Since it did not does this mean we only need to make sure the code is set to "no error reported" not "disabled"?
    Oct 2011
    Gainesville, VA
    301
    Pretty sure it's No error reported. That's what I've been using and it's flashed fine with a calibration write only.
    Sep 2010
    872
    Awesome, thats what I figured but wanted to be sure.
    Sep 2010
    872
    Wrapped up a tuning session over the weekend and got to say the "write calibration" functions saves so much time
    Tuning Addict
    Jan 2015
    6,781
    It didn't save me a whole lot of time on the whipple tune OS - honestly seconds If that, but saved LOTS of time on the Roush OS I tuned today... May have just been the Roush OS as they cause issues randomly on their own, but has anyone had problems with traction and stabilitrac lights randomly coming on with engine fire up after doing it this way? Honestly was probably just where I forgot to do a full vehicle DTC clear after dynoing and completely my fault, but wanted to make sure - all lights went out after driving a second time like they did the first time - thought they would have stayed off after passing everything the first drive?
    ~Greg Huggins~
