Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: Copperhead Calibration Only Reflashing now in VCM Suite 3.7 Beta
  1. #21
    May 2016
    1,134
    Was the Whipple a 2015+ and the Roush an 11-14? 15+ already supported Write Calibration mode.
  2. #22
    Tuning Addict
    Jan 2015
    6,789
    Well, that's probably why I didn't notice any difference on the whipple - it was a 15' and the roush as you know a 14 Curious now - other than a more complex OS - why do the 15 and newers take longer?
    ~Greg Huggins~
  3. #23
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    Aftermarket supercharger calibrations do not and will not have a calibration flash option unfortunately.
  4. #24
    Tuning Addict
    Jan 2015
    6,789
    Well, the Roush did - guess it was just a fortunate mishap then Didn't screw anything up using the cal flash option did I? Need to do write entires on all of these?
    Thank You
    ~Greg Huggins~
  5. #25
    Jul 2008
    39
    Eric
    Will this work on the ESYS 2048k for the 3.7 V6 the same way calib.write only ????
    Tony
  6. #26
    Jan 2015
    fecadefa
    615
    Yes.
  7. #27
    Jul 2008
    39
    Awesome!! Eric great work you are the best !!!!
    Thanks for all the hard work !!!!!
    Tony K.
  8. #28
    Oct 2007
    Crawfordville, FL
    2,412
    Thank You
    You can do a cal write on all the Copperheads, even the Roush files. The 2015+ aftermarket cals require full write.
    Eric Brooks
    HP Tuners, LLC
  9. #29
    Tuning Addict
    Jan 2015
    6,789
    Perfect, Thank You Eric
    ~Greg Huggins~
  10. #30
    Flashed a 2014 last night. Made sure p0605 was disabled. Now it's lighting up stability and advance trac lights, PATS light is on, key does nothing. Scanner will not connect to vehicle.
    Did a full rewrite, and a calibration flash to no avail. Car is not responding.
  11. #31
    Oct 2016
    Poland
    1,738
    Oh czit. You may try flashing it back to stock with IDS.
  12. #32
    Greaaaaaaat
  13. #33
    Jan 2021
    18
    Hello All,
    New to tuning and recently did a write calibration to a copperhead ECU without first disabling P0605. What needs to be done now to turn off this CEL? Will I need to Write Entire with the new tune file and P0605 disabled?
  14. #34
    Feb 2017
    TX
    761
    Quote Originally Posted by Aggie3rdGen View Post
    Hello All,
    Disable it and reflash the file.
  15. #35
    Apr 2018
    605
    Hello All,
    Disable and do the write cal again. I wouldn't ever do a write entire unless changing the strategy.
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
  16. #36
    Jan 2021
    18
    Thank you both for the replies. I've attempted to write calibration with the P0605 DTC disabled as stated, with no immediate avail. As this is a "permanent" code(apologies if I failed to mention this), will it eventually go away after driving the vehicle? Has anyone been successful at erasing this permanent code by performing a "write entire"?
    Also,
    What is meant by "changing strategy", specifically?
  17. #37
    Feb 2017
    TX
    761
    I think if this code was active, it would cause a no start. Does your car start and run? You may need to put some miles on it and the code will clear itself.
    The strategy is the Operating System. Similar to going from windows 7 to windows 8 or to Linux. It's like a new foundation, and there may only be minor changes in different strategies, a couple of tables may be different or have more or less tables from one strategy to another.
    I too only use write calibration and write entire for changing strategies. I have a 2012 with a stock strategy and a 2014 strategy. I run the 14 strategy and use write calibration only flashing adjustments.
