Results 1 to 10 of 10
Thread: Cobra Jet MAF transfer
    May 2015
    1,908
    I am going to install a CJ cold air intake on a whipple vehicle, and I am curious if anyone has the MAF data?
    Part of me says it should be the same or similar to the Whipple calibration, which uses a same 123MM MAF and would be logical is similar to the CJ.
    Sep 2010
    872
    You could always scale the MAF up by using the equation in the MAF calibration thread. Then adjust using LTFT+STF(assuming all injector and fuel pressure data is accurate). That should get you pretty close to +/-5%
    May 2015
    1,908
    Thanks, that was my original plan, but since they are both 123MM I think I will just start with the Whipple calibration and go from there.
    Sep 2010
    872
    Quote Originally Posted by 06300CSRT8 View Post
    That should work fine as a base...
    Dearborn, MI
    92
    What about the 2016 CJ calibration file that's in the repository?
    Quote Originally Posted by Jn2 View Post
    Where is this thread located. I searched but I do not see it.
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    Which car do you need this for? Which CAI and TB?
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Feb 2012
    TEXAS
    636
    i have the Maf 123mm JLT
    The M-9600-SCJ16 is 140mm at the MAF sensor location. I want to use that with the Whipple Stage II. So my math would be:
    Whipple Radius= 123mm/2 61.5mm
    Cobra Jet Radius= 140mm/2 70mm
    Area of circles= Pi(61.5mm)2 Pi(70mm)2
    Area= 11882.28881 15393.80400
    Area of WS MAF 11882.28881
    Area of SCJ MAF 15393.80400
    Ratio of new to old area 15393.80400 / 11882.28881
    Ratio of WS area to SCJ area= 1.295525150595965
    Multiply all of the lb/min airflow values in the MAF curve by 1.295525150595965
    Thanks @AKDMB
