Installed a Fore twin-pump return system and wanted to keep the pressure sensor, so I'm keeping the FPCM and using the old pump power wire to signal the Fore pump controller. Problem is I can't get the FPCM to output more than 10v, so the P023f gets set. As an experiment I tied in a BAP and the code went away but with the FPCM freaking out trying to regulate the voltage, the pump controller became erratic and fuel pressure was all over the place. Has anyone tried putting in a resistor somewhere in the circuit? Or is there another solution? if I could get that damn FPCM to kick out another two volts I'd be golden!
