I am tuning a 2015 Z06 and struggling with the torque management. I have tried raising the values but the car is not going wot for an entire dyno pull. I have messed around with the driver demand and virtual torque with little success. I was able to stop it from pulling rediculous spark by adjusting the virtual torque but the throttle is still closing even with the values in driver demand raised significantly. What is the proper way to adjust these tables? Do you typically use the dyno to get the actual torque figure? I will post my file and log later when I get to my computer. I've also noticed I have knock that I can't seem to get rid of. It's my understanding this may be do to the SOI being to low or "late". Is this likely the cause? How do you go about adjusting these values. I am hesitant to change them and unsure how much they need to be changed. Thanks in advance for any help!
