Results 1 to 20 of 22
Thread: 2017 Buick encore 1.4 turbo
    Nov 2015
    42
    What is eta on support for 2017 Buick Encore 1.4 turbo ?
    Feb 2008
    665
    Have you just tried a read from the vehicle with the newest software version of Hptuners? If so and wouldn't read then send the info log to Hptuners support and they can work on seeing if they can get the pcm/os supported if it's not yet.
    2017 Silverado LTZ
    Nov 2015
    42
    thnaks for yuo reply
    I'd like to see this too, (we also own one), but unfortunately I was told I'd need to remove the ECM to get to the barcode, which I don't feel comfortable doing.
    Nov 2015
    42
    i can read my encore
    i add my file
    I was able to read mine too, and emailed it to HPTuners support, but they didn't know what ECM I had, and asked me to pull the ECM (by the battery under the hood) to get a clear picture of the barcode.
    Nov 2015
    42
    the technical support (willian ) tall me i can tune my vehicle
    May 2006
    Seattle, WA
    539
    Looking at Buick's site, it's still a port-injected 1.4T which means it uses the E78 GM's been using since ~2010. I know for 2017, it's the E78A that has the new read encryption that requires you to be connected to the internet when attempting to read the first time, then you need to try it again after 30min as HPT will send your computer the correct bootloader unlock code to allow you to read it.
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    This vehicle is supported in the 3.7 beta software.
    Nov 2015
    42
    my encore it is tuned now
    Quote Originally Posted by TownDrunk View Post
    Some GM cars have the ECM out front and easy to get at.
    E67 - 2006 LE5 2.4 Turbo, 444 whp
    E78 - 2013 LUV 1.4T
    Quote Originally Posted by Luis_Panic View Post
    Can I ask what you changed? I'm pretty comfortable with my Volt, but it's a completely different animal than the turbo on my Encore.
    May 2006
    Seattle, WA
    539
    Play with the Peak Torque table, Boost Limits, and Base DC to start. There's a small write-up on the Sonicownersforum with some helpful tips as well, a quick Google should get you there!
    ~Erik~
    Sounds like you mean the sticky: http://www.sonicownersforum.com/foru...ing-1-4-a.html
    Thanks I'll take a look at it when I get a chance, but the body shop will have it for about a week (clear coat coming off the bumper) so won't be able to do much with it, except maybe read-all and license it.
    I wanted to play with the shift points to make it a bit more responsive for city driving without getting into the turbo. Published zero to 60 times for the Encore are better than my 3500 lb 1.4 liter Volt, yet it drives like a dog for normal driving. Too bad they didn't think to add a sport mode button.
    May 2006
    Seattle, WA
    539
    Yes, play with the TCM side a BUNCH. GM likes to make their transmissions shift soft and smooth, great for most people but for those who care it's horrible. Shoot me a PM when you have it back and I'm happy to help review your tune and offer some pointers!
    ~Erik~
    My tuning buddy has years of experience and has been looking at it too, but he's about 8 states away so tuning blind.
    Play with yours a bit and I'll do the same and we can compare later.
    Thanks again.
    Tuner Stevo's Avatar
    Mar 2011
    Melbourne
    86
    Modifying MAP A will help a lot.
    Oct 2010
    213
    Quote Originally Posted by ScarabEpic22 View Post
    The E78A is used in the Direct Injection "new version" 1.4 Turbo with aluminum block.
    Dec 2006
    OH-IO!
    43
    Quote Originally Posted by sprinto7 View Post
    Encore Sport, or the Opel version sans badging but extra sound deadening.
