RaceRender Diagnostic Log Output
If you are encountering problems, copy & paste this entire log into a message
to us at
http://RaceRender.com/Contact.html
Please do this immediately after the problem occurs, and be sure to include
specific details about what happened, how to reproduce the problem, the type
of files you were using, etc.
*** Current Session Log ***
2017-07-12 11:52:28,"[Log Start]"
2017-07-12 11:52:28,"Session ID: 3CA2AF85"
2017-07-12 11:52:28,"Process ID: 5432"
2017-07-12 11:52:28,"Prod: 'RaceRender' Ver: '3.5.8b' Build: '20170624' OEM: 0"
2017-07-12 11:52:28,"32-bit Build"
2017-07-12 11:52:28,"Windows 32-bit version 6.1 SP1.0 (build 7601 'Service Pack 1') on platform 2"
2017-07-12 11:52:28,"CPU ID: AMD Phenom(tm) II X4 955 Processor"
2017-07-12 11:52:28,"CPU Count: 4 Arch: 0x0000"
2017-07-12 11:52:28,"Process Memory: 78 MB used"
2017-07-12 11:52:28,"Physical Memory: 1692 MB available / 3325 MB total"
2017-07-12 11:52:28,"Virtual Screen Size: 4480 x 1440 (Offset: 0, 0)"
2017-07-12 11:52:28,"Primary Screen Size: 2560 x 1440"
2017-07-12 11:52:28,"Docs Dir: 'C:\Users\jat\Documents'"
2017-07-12 11:52:28,"Assets Dir: 'C:\Program Files\RaceRender3'"
2017-07-12 11:52:28,"Library Path: 'C:\Program Files\RaceRender3\RaceRender3c.dll'"
2017-07-12 11:52:28,"Program Path: 'C:\Program Files\RaceRender3\RaceRender3.exe'"
2017-07-12 11:52:28,"Previous session may not have exited cleanly. Process # 5236"
2017-07-12 11:52:28,"Loading previous session's crash report"
2017-07-12 11:52:28,"***NO PREVIOUS SESSION CRASH REPORT***"
2017-07-12 11:52:28,"Previous session appears to have crashed and is recoverable."
2017-07-12 11:52:28,"Edition: 3"
2017-07-12 11:52:28,"Loading QuickTime interface..."
2017-07-12 11:52:37,"QuickTime support enabled"
2017-07-12 11:52:37,"Loading Media Foundation interface..."
2017-07-12 11:52:42,"Media Foundation support enabled"
2017-07-12 11:52:42,"Loading Windows Media interface..."
2017-07-12 11:52:43,"Windows Media support enabled"
2017-07-12 11:52:43,"Loading DirectShow interface..."
2017-07-12 11:52:43,"DirectShow support enabled (0)"
2017-07-12 11:52:43,"Loading AVI (VfW) interface..."
2017-07-12 11:52:43,"Started 4 RenderFrame threads"
2017-07-12 11:52:43,"RenderFrameThread 0 started"
2017-07-12 11:52:43,"RenderFrameThread 1 started"
2017-07-12 11:52:43,"RenderFrameThread 2 started"
2017-07-12 11:52:43,"RenderFrameThread 3 started"
2017-07-12 11:52:43,"Special Save Project 'C:\Users\jat\AppData\Local\Temp\RR3-undo-3CA2AF85.rrp' (Mode 1)"
2017-07-12 11:52:43,"[Code] -21 'AudioOutVolume'"
2017-07-12 11:52:43,"SetMediaLibEnable(0xFFFFFFFF)"
2017-07-12 11:52:43,"RenderEnd()"
2017-07-12 11:52:43,"RenderInit(1920x1080 [4], 29.970 FPS, Audio Type 3 @ 22050 Hz, PreviewMode 1)"
2017-07-12 11:52:43,"Process Memory: 209 MB used"
2017-07-12 11:52:43,"Physical Memory: 1555 MB available / 3325 MB total"
2017-07-12 11:52:43,"[Code] 1000 'RecoveryStatus'"
2017-07-12 11:52:56,"Recovering previous session..."
2017-07-12 11:52:56,"Open Project 'C:\Users\jat\AppData\Local\Temp\RR3-undo-B3351935.rrp'"
2017-07-12 11:52:56,"Open input file [0] 'G:\av\video\track\BMP-2017-07-08-09\data\BMP-2017-07-09-sess5.csv'"
2017-07-12 11:52:56,"Attempting MediaDataloggerOpen('G:\av\video\track\BMP-2017-07-08-09\data\BMP-2017-07-09-sess5.csv', New:0)"
2017-07-12 11:52:56,"[Code] -1 'MediaDataloggerOpenGoProFile'"
2017-07-12 11:52:56,"[Code] -84 'MediaDataloggerOpenFitFile'"
2017-07-12 11:53:10,"NMEA Samples: 0 (RMC: 0, GGA: 0, GLL: 0)"
2017-07-12 11:53:10,"[Code] -1 'MediaDataloggerOpenNmeaFile'"
2017-07-12 11:53:10,"[Code] -81 'MediaDataloggerOpenXmlFile'"
2017-07-12 11:53:10,"File sample contains 3210 commas, 0 tabs, 0 semi-colons, and 0 bars. Separator value: 44"
2017-07-12 11:53:10,"Skipping 'Comment' field"
2017-07-12 11:53:10,"31 beacon markers detected (Separator: 44)"
2017-07-12 11:53:10,"Column 0: 'Time'"
2017-07-12 11:53:10,"Column 1: 'Distance'"
2017-07-12 11:53:10,"Column 2: 'Logger Temperature'"
2017-07-12 11:53:10,"Column 3: 'External Voltage'"
2017-07-12 11:53:10,"Column 4: 'steering_angle'"
2017-07-12 11:53:10,"Column 5: 'oil_pres'"
2017-07-12 11:53:10,"Column 6: 'oil_temp'"
2017-07-12 11:53:10,"Column 7: 'brake_pres'"
2017-07-12 11:53:10,"Column 8: 'AccelerometerX'"
2017-07-12 11:53:10,"Column 9: 'AccelerometerY'"
2017-07-12 11:53:10,"Column 10: 'AccelerometerZ'"
2017-07-12 11:53:10,"Column 11: 'GyroX'"
2017-07-12 11:53:10,"Column 12: 'GyroY'"
2017-07-12 11:53:10,"Column 13: 'GyroZ'"
2017-07-12 11:53:10,"Column 14: 'Luminosity'"
2017-07-12 11:53:10,"Column 15: 'PreCalcGear'"
2017-07-12 11:53:10,"Column 16: 'OBDII_RPM'"
2017-07-12 11:53:10,"Column 17: 'OBDII_ECT'"
2017-07-12 11:53:10,"Column 18: 'OBDII_TPS'"
2017-07-12 11:53:10,"Column 19: 'OBDII_IAT'"
2017-07-12 11:53:10,"Column 20: 'OBDII_MAP'"
2017-07-12 11:53:10,"Column 21: 'OBDII_MAF'"
2017-07-12 11:53:10,"Column 22: 'OBDII_PPS'"
2017-07-12 11:53:10,"Column 23: 'GPS_Speed'"
2017-07-12 11:53:10,"Column 24: 'GPS_Nsat'"
2017-07-12 11:53:10,"Column 25: 'GPS_LatAcc'"
2017-07-12 11:53:10,"Column 26: 'GPS_LonAcc'"
2017-07-12 11:53:10,"Column 27: 'GPS_Slope'"
2017-07-12 11:53:10,"Column 28: 'GPS_Heading'"
2017-07-12 11:53:10,"Column 29: 'GPS_Gyro'"
2017-07-12 11:53:10,"Column 30: 'GPS_Altitude'"
2017-07-12 11:53:10,"Column 31: 'GPS_PosAccuracy'"
2017-07-12 11:53:10,"Column 32: 'GPS_SpdAccuracy'"
2017-07-12 11:53:10,"Column 33: 'GPS_FreqAccuracy'"
2017-07-12 11:53:10,"Column 34: 'GPS_Latitude'"
2017-07-12 11:53:10,"Column 35: 'GPS_Longitude'"
2017-07-12 11:53:10,"Column 36: 'GPS_Elevation'"
2017-07-12 11:53:10,"Sample Rate: 50.00 Hz"
2017-07-12 11:53:23,"Skipping 1 row with apparent junk timestamp (0.000 < 80.268)"
2017-07-12 11:53:24,"Skipping 1 row with apparent junk timestamp (0.000 < 118.183)"
2017-07-12 11:53:25,"Skipping 1 row with apparent junk timestamp (0.000 < 116.913)"
2017-07-12 11:53:25,"Skipping 1 row with apparent junk timestamp (0.000 < 116.611)"
2017-07-12 11:53:26,"Skipping 1 row with apparent junk timestamp (0.000 < 116.228)"
2017-07-12 11:53:27,"Skipping 1 row with apparent junk timestamp (0.000 < 116.448)"
2017-07-12 11:53:29,"Skipping 1 row with apparent junk timestamp (0.000 < 351.192)"
2017-07-12 11:53:29,"Skipping 1 row with apparent junk timestamp (0.000 < 118.930)"
2017-07-12 11:53:30,"Skipping 1 row with apparent junk timestamp (0.000 < 117.775)"
2017-07-12 11:53:31,"Skipping 1 row with apparent junk timestamp (0.000 < 117.929)"
2017-07-12 11:53:31,"Skipping 1 row with apparent junk timestamp (0.000 < 116.931)"
2017-07-12 11:53:32,"Skipping 1 row with apparent junk timestamp (0.000 < 119.524)"
2017-07-12 11:53:33,"Skipping 1 row with apparent junk timestamp (0.000 < 121.367)"
2017-07-12 11:53:33,"Skipping 1 row with apparent junk timestamp (0.000 < 118.475)"
2017-07-12 11:53:34,"Skipping 1 row with apparent junk timestamp (0.000 < 122.450)"
2017-07-12 11:53:35,"Skipping 1 row with apparent junk timestamp (0.000 < 118.171)"
2017-07-12 11:53:35,"Skipping 1 row with apparent junk timestamp (0.000 < 118.424)"
2017-07-12 11:53:36,"Skipping 1 row with apparent junk timestamp (0.000 < 116.515)"
2017-07-12 11:53:37,"Skipping 1 row with apparent junk timestamp (0.000 < 116.486)"
2017-07-12 11:53:37,"Skipping 1 row with apparent junk timestamp (0.000 < 117.020)"
2017-07-12 11:53:38,"Skipping 1 row with apparent junk timestamp (0.000 < 119.438)"
2017-07-12 11:53:39,"Skipping 1 row with apparent junk timestamp (0.000 < 122.051)"
2017-07-12 11:53:39,"Skipping 1 row with apparent junk timestamp (0.000 < 119.187)"
2017-07-12 11:53:40,"Skipping 1 row with apparent junk timestamp (0.000 < 122.283)"
2017-07-12 11:53:41,"Skipping 1 row with apparent junk timestamp (0.000 < 118.939)"
2017-07-12 11:53:41,"Skipping 1 row with apparent junk timestamp (0.000 < 118.066)"
2017-07-12 11:53:42,"Skipping 1 row with apparent junk timestamp (0.000 < 119.621)"
2017-07-12 11:53:43,"Skipping 1 row with apparent junk timestamp (0.000 < 119.451)"
2017-07-12 11:53:43,"Skipping 1 row with apparent junk timestamp (0.000 < 118.767)"
2017-07-12 11:53:44,"Skipping 1 row with apparent junk timestamp (0.000 < 119.047)"
2017-07-12 11:53:45,"Datalogger Type: 6"
2017-07-12 11:53:45,"Detected Time column (0): 'Time sec' Units: 1.000000 Conv: 1.000000"
2017-07-12 11:53:45,"MediaDataloggerUpdate(0)"
2017-07-12 11:53:45,"0 duplicate timestamps detected (196617 total rows)"
2017-07-12 11:53:45,"Position Range: -86.624399,33.529299 - -86.608383,33.538141"
2017-07-12 11:53:45,"Setting GPS Curve Data"
2017-07-12 11:53:45,"Setting Gear Calc Data"
2017-07-12 12:06:51,"MediaDataloggerUpdate(0)"
2017-07-12 12:06:51,"Detected Time column (0): 'Time sec' Units: 1.000000 Conv: 1.000000"
2017-07-12 12:06:51,"0 duplicate timestamps detected (196617 total rows)"
2017-07-12 12:06:51,"Position Range: -86.624399,33.529299 - -86.608383,33.538141"
2017-07-12 12:06:51,"Setting GPS Curve Data"
2017-07-12 12:06:51,"Setting Gear Calc Data"
2017-07-12 12:06:51,"Successful open of input file [0] F:0 A:0 D:1 G:1"
2017-07-12 12:06:51,"0 x 0 (0 BPP), 3932.29 seconds"
2017-07-12 12:06:51,"0 Hz, 0-bit, 0 channels"
2017-07-12 12:06:52,"Position Range: -86.624399,33.529299 - -86.608383,33.538141"
2017-07-12 12:06:52,"Setting GPS Curve Data"
2017-07-12 12:06:52,"Setting Gear Calc Data"
2017-07-12 12:06:52,"Open input file [1] 'G:\av\video\track\BMP-2017-07-08-09\front09\front45c.mp4'"
2017-07-12 12:06:52,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\front09\front45c.mp4')"
2017-07-12 12:06:53,"MF length: 696.829"
2017-07-12 12:06:53,"MediaInfo length: 696.829"
2017-07-12 12:06:56,"Successful open of input file [1] F:7 A:7 D:0 G:0"
2017-07-12 12:06:56,"1920 x 1080 (32 BPP), 696.83 seconds"
2017-07-12 12:06:56,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:06:56,"Open input file [2] 'G:\av\video\track\BMP-2017-07-08-09\front09\front45d.mp4'"
2017-07-12 12:06:56,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\front09\front45d.mp4')"
2017-07-12 12:06:57,"MF length: 697.497"
2017-07-12 12:06:57,"MediaInfo length: 697.497"
2017-07-12 12:07:00,"Successful open of input file [2] F:7 A:7 D:0 G:0"
2017-07-12 12:07:00,"1920 x 1080 (32 BPP), 697.50 seconds"
2017-07-12 12:07:00,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:00,"Open input file [3] 'G:\av\video\track\BMP-2017-07-08-09\front09\front45e.mp4'"
2017-07-12 12:07:00,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\front09\front45e.mp4')"
2017-07-12 12:07:01,"MF length: 697.363"
2017-07-12 12:07:01,"MediaInfo length: 697.363"
2017-07-12 12:07:05,"Successful open of input file [3] F:7 A:7 D:0 G:0"
2017-07-12 12:07:05,"1920 x 1080 (32 BPP), 697.36 seconds"
2017-07-12 12:07:05,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:05,"Open input file [4] 'G:\av\video\track\BMP-2017-07-08-09\front09\front45f.mp4'"
2017-07-12 12:07:05,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\front09\front45f.mp4')"
2017-07-12 12:07:06,"MF length: 697.363"
2017-07-12 12:07:06,"MediaInfo length: 697.363"
2017-07-12 12:07:09,"Successful open of input file [4] F:7 A:7 D:0 G:0"
2017-07-12 12:07:09,"1920 x 1080 (32 BPP), 697.36 seconds"
2017-07-12 12:07:09,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:09,"Open input file [5] 'G:\av\video\track\BMP-2017-07-08-09\front09\front45g.mp4'"
2017-07-12 12:07:09,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\front09\front45g.mp4')"
2017-07-12 12:07:10,"MF length: 697.497"
2017-07-12 12:07:10,"MediaInfo length: 697.497"
2017-07-12 12:07:14,"Successful open of input file [5] F:7 A:7 D:0 G:0"
2017-07-12 12:07:14,"1920 x 1080 (32 BPP), 697.50 seconds"
2017-07-12 12:07:14,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:14,"Open input file [6] 'G:\av\video\track\BMP-2017-07-08-09\front09\front45h.mp4'"
2017-07-12 12:07:14,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\front09\front45h.mp4')"
2017-07-12 12:07:14,"MF length: 221.405"
2017-07-12 12:07:14,"MediaInfo length: 221.405"
2017-07-12 12:07:18,"Successful open of input file [6] F:7 A:7 D:0 G:0"
2017-07-12 12:07:18,"1920 x 1080 (32 BPP), 221.40 seconds"
2017-07-12 12:07:18,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:18,"Input file [7] special: *JOINV*"
2017-07-12 12:07:18,"Open input file [8] 'G:\av\video\track\BMP-2017-07-08-09\rear09\rear4b.mp4'"
2017-07-12 12:07:18,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\rear09\rear4b.mp4')"
2017-07-12 12:07:19,"MF length: 1046.045"
2017-07-12 12:07:19,"MediaInfo length: 1046.045"
2017-07-12 12:07:21,"Successful open of input file [8] F:7 A:7 D:0 G:0"
2017-07-12 12:07:21,"1920 x 1080 (32 BPP), 1046.05 seconds"
2017-07-12 12:07:21,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:21,"Open input file [9] 'G:\av\video\track\BMP-2017-07-08-09\rear09\rear4c.mp4'"
2017-07-12 12:07:21,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\rear09\rear4c.mp4')"
2017-07-12 12:07:22,"MF length: 413.647"
2017-07-12 12:07:22,"MediaInfo length: 413.647"
2017-07-12 12:07:25,"Successful open of input file [9] F:7 A:7 D:0 G:0"
2017-07-12 12:07:25,"1920 x 1080 (32 BPP), 413.65 seconds"
2017-07-12 12:07:25,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:25,"Input file [10] special: *JOINV*"
2017-07-12 12:07:25,"Open input file [11] 'G:\av\video\track\BMP-2017-07-08-09\rollbar09\rollbar45b.mp4'"
2017-07-12 12:07:25,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\rollbar09\rollbar45b.mp4')"
2017-07-12 12:07:25,"MF length: 1063.062"
2017-07-12 12:07:25,"MediaInfo length: 1063.062"
2017-07-12 12:07:28,"Successful open of input file [11] F:7 A:7 D:0 G:0"
2017-07-12 12:07:28,"1920 x 1080 (32 BPP), 1063.06 seconds"
2017-07-12 12:07:28,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:28,"Open input file [12] 'G:\av\video\track\BMP-2017-07-08-09\rollbar09\rollbar45c.mp4'"
2017-07-12 12:07:28,"Attempting MediaMfOpen('G:\av\video\track\BMP-2017-07-08-09\rollbar09\rollbar45c.mp4')"
2017-07-12 12:07:29,"MF length: 1063.062"
2017-07-12 12:07:29,"MediaInfo length: 1063.062"
2017-07-12 12:07:31,"Successful open of input file [12] F:7 A:7 D:0 G:0"
2017-07-12 12:07:31,"1920 x 1080 (32 BPP), 1063.06 seconds"
2017-07-12 12:07:31,"48000 Hz, 16-bit, 2 channels"
2017-07-12 12:07:31,"Input file [13] special: *JOINV*"
