Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Any experience w/ "Injector gain vs cyl" ECM 12313
    Baltimore, Md
    1,208
    In the bottom it says may causes issues with high rpm operation???
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Australia
    1,978
    i have adjusted my injector gain and it was fine with light driving then with a throttle stomp it just lost all power for a sec then regained so i change it back to stock and problem gone, i may try it again and sneak it in with small steps and see how it goes encase it was too much at one time
    Tuning Addict
    6,788
    I use it all the time on large boosted Eaton based superchargers. Haven't had any problems as long as you don't modify the driver demand tables. The ecm can't handle both modifications at the same time.
    ~Greg Huggins~
    Does this function provide the ability to modify the fueling on individual injectors ?
    Tuning Addict
    6,788
    Yes, just go with small adjustments at a time while reading the plugs. If you have any leaner cylinders you might be surprised by what you can gain doing this.
    ~Greg Huggins~
    Good advice, this will help with the rear cylinders on LSA's
    Is there a reference or picture for which injectors is which with the labelling ??
    Tuning Addict
    6,788
    Forgot the table name, but look up at the top of the page. Should help you out there. I can post cylinders later if need be.
    ~Greg Huggins~
    Yeah that's what I meant Cylinder A = 1 etc??
    A1, B8, C7, D2, E6, F5, G4, H3
    Tuning Addict
    6,788
    This Might help or at least get somewhat close on a Eaton
    Cyl #A 1.01
    Cyl #B 1.095
    Cyl #C 1.055
    Cyl #D 1.04
    Cyl #E 1.095
    Cyl #F 1.045
    Cyl #G 1.06
    Cyl #H 1
    ~Greg Huggins~
    Australia
    1,978
    driver demand tables..? is that like VE table at some time
    Tuning Addict
    6,788
    Sorry - gen 4 - desired throttle area tables - don't modify those and this both - will always put into REP and set ECM memory and logic faults...
    ~Greg Huggins~
    Australia
    1,978
    ok yea thinking back i may have been making small changes to some of those at same time, the cyl gain table is one i was wanting to change too so now ill have another go
    Australia
    1,978
    i was using this just to help simplify which cylinder is what
    Apr 2007
    1,104
    Cyl #A 1.01
    Cyl #B 1.095
    Cyl #C 1.055
    Cyl #D 1.04
    Cyl #E 1.095
    Cyl #F 1.045
    Cyl #G 1.06
    Cyl #H 1
    like 2600+ eatons, or all of them?
    93 Ranger. 5.3 D1X. 1069hp.
    Tuning Addict
    6,788
    2300+ 1900's with 15+psi, but won't need that radical of adjustments / The above tables are from a 2300 heartbeat running 18psi
    ~Greg Huggins~
    Apr 2007
    1,104
    Ah, gotcha. say you have one at 16 psi. I need to find a faster way to pull plugs on the LSA. such a pain in the butt.
    Tuning Addict
    6,788
    Yes - big pain - I like to do 3 or 4 wot dyno pulls before even bothering to pull the plugs too - makes it easier to read them or instantly see fueling adjustments... Then maybe not tighten so tight until ready to call it good
    ~Greg Huggins~
    Aug 2011
    Alaska
    566
    I played with this table a couple years ago, trying to balance out a bank to bank imbalance I see at lower rpm. It seemed to help under 2000 rpm, but holy crap......WOT and fueling went bonkers. AFR was all over the place. I got skeered and put the table back to stock values, never messed with it again. This was an N/A application, so maybe it works better for boost?? Either that or I did something stupid and did not realize it at the time. Regardless, I would not mess with injector gain unless you have the WB installed and can verify WOT AFR.
    When arguing with an idiot, make sure he isn't doing the same thing....
    Tuning Addict
    6,788
    Quote Originally Posted by Michael_D View Post
    Tq Model is another set of tables that won't play well with this - Do not modify individual tables in the tq model and this table - have seen it lean out bank 2 if just modifying the airmass tables / BUT if you modify the tq model via tq editor - all seems to work good... That part applies to more tables then just this one though...
    Also don't recommend adjusting this for bank to bank fueling - only adjust for wot cylinder to cylinder lean issues... Might be why wot fueling went screwy for you Michael?
    ~Greg Huggins~
    Aug 2011
    Alaska
    566
    I dunno....
    Never thought to use it for WOT tuning of individual cylinders. How would you know which one is lean without an O2 sensor or EGT probe on every primary tube?
