I'm stumped.. Bad IAC? Case learn? Checked for vacuum leaks with carb spray and there appear to be none.
Seems like you have an o2 sensor issue on your hands.
Bank 1 is constantly rich and it's trying to yank fuel away while bank 2 shows that it's way lean and doing the opposite. Having one stuck at 900mv and the other at 50-100mv all the time is going to give you problems.
Swap sensors side to side, see if the problem switches sides. Check wiring.
Yep..you were right...O2 sensors cross-wired. Bank 1 O2 reading bank 2 and Bank 2 O2 reading bank 1. I figured that was the problem..guess I should have checked it. My engine came with the PCM connectors chopped off the harness and I had to reconstruct the whole thing.
Also had a bad IAC valve, replaced that and rewired the O2 sensors and runs 4.0.
