LC1 settings
Can you get into the LC1 settings without using the serial connector.
I keep getting connect serial connector,or i need a serial to usb adapter.
Iam getting a WB afr reading.
yes....go get a KeySpan USB device and you will have no issues
I think I paid about $40 for mine at any Comp Usa store
its also important that you use a comp port that is 1-4...not any higher with the LC1
alo you need the terminator plug in the "in" side of the LC1 and you plug the data cable into the "out" side of it
