Originally Posted by
ridenrunwv
Under the Idle -> General tab maybe try setting Minimum VSS to 0 mph and I'm not sure if you also need to do this but Enable RPM Error to something higher. Not sure if it will help with the timing but would probably get a cleaner log if it lets the RPMs go higher. Might end up needing to request more torque in Idle Reserve and Idle IPC / Allow a higher max and min torque correction also.
This is just a guess because I've never even tried a ghost cam S550 tune but it's worth a try. Maybe the guy that's done it will give more info. If I get one this weekend I'll play around with it some for you.
