Results 1 to 9 of 9
Thread: Upgrade to 2bar OS ...
    Feb 2016
    Katy, Tx
    27
    Hello, wanted to see how to upgrade to a 2bar OS system so I can reset my fan control settings. can someone help me out on this...Thanks in advance
    28,301
    The OS tab should have all the available custom operating systems/patches
    also make sure you are in advanced mode in order to see them.
    13,598
    You will also have to re-create your 3 new VE tables on the GEN 4 vehicles, otherwise the vehicle will never run.
    Feb 2016
    Katy, Tx
    27
    This is what I see, is this Advanced Mode?
    Feb 2016
    Katy, Tx
    27
    this is for a 06 tbss, i believe that's a gen 3..
    13,598
    E40's are GEN 4 computers, just click Edit > calibration details > controllers.
    I'd have to open a tbss tune file but it may or may not create new VE table, it may just add a boost table like the GTO computers.
    E38's would create 3 VE tables for sure.
    May 2006
    Seattle, WA
    539
    Just click the 2 Bar OS there, and save the new file. Re-open it and you should see the new fan axis. As far as VE, since the E40 has a regular VE you should be ok (check it though). Make sure the Boost VE or over 105kPa values are set to something sane.
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    Feb 2016
    Katy, Tx
    27
    I followed your direction, am I suppose to be in advance mode to see options in controllers window? And if so, how do you change to advance mode? Please advise and Thanks
    May 2006
    Seattle, WA
    539
    You already have Advanced mode on and had the OS upgrade in your previous screenshot, just click the "Apply Code Modification" button.
    ~Erik~
