Howdy folks.
Im about to tackle a 2007 or 2008 Magnum with a 5.7 in it. Im going to play with the shift points using the TCM calculator. This car is also getting a diff ratio swap. Is there a way to compensate for the gear ratio swap or are the shift points based strictly on output speed. Is there a way to compensate for higher stall torque converters or is it still an output speed thing.
Thanks in advance
