07-08-?? Auto Corvette 6L80e trans looses shift function after tune
I'm am posting this up as help to others who have ran into this before. In 07, 08 thru?? Corvette with 6L80e trans, if the "Max Torque" value under traction control in the Engine side of the tune is adjusted, you will lose trans shifting functions for all modes. No worries, if the value was adjusted and it is return to stock the problem will go away. Most wont adjust this value but for those that normally do it is good to know how to fix it. Support ticket is in to look into it but it is not a sever problem unless you are stuck with a trans that isn't working and have put a stock trans tune back in and still doing the same thing.
Rick Crawford
2009 Pontiac G8GT
11.65 @118.55 1.72 60ft DoD cam, 2600 stall, Crawford ported heads and intake, stock wheels and BFG-KDW tires
9.95 @134.9 388, 3.45 gear, stock 6L80e ALL Motor!!
[email protected] 417 LSA Blower-Only, 6L80e, 3.45
