Page 7 of 8 FirstFirst ... 345678 LastLast
Results 121 to 140 of 142
Thread: 6L90E Help
  1. #121
    Tuning Addict
    6,795
    You need to keep a couple of things in mind too - such as your tune was scaled the "old way" - used airflow tables instead of the double stoic method... Unless you've completely retuned it - your going to want to almost double the values to begin with... I always try to shoot for over what the transmission will ever see - especially if it's a near stock trans - this will really help with shifts... I've seen "dialed into actual" torque models keep tranny's from making the shift in time no matter how much editing was done to the trans side... Try to target 900 to 1000 in the torque output at least...
    These transmissions have to be run hard to learn in - don't be afraid to go at least 3/4 throttle when doing the initial shifting learn - this is even per GM after doing the initial relearn on the scanner...
    ~Greg Huggins~
  2. #122
    I haven?t changed the tune. I reached out to the tuning school for more info on the VT tables and below is a link of the video they made for me. The gentlemen reviewing the tune tonight but says the actual torque and calculated torque is matching at the shift points and isn?t seeing anything
    https://share.vidyard.com/watch/R631BbFwqhPp2Fz5G1ytKc
  3. #123
    I just don?t have faith in taking it just to another tuner as I don?t have any faith that the next tuner can get it correct.
  4. #124
    Tuning Addict
    6,795
    Tell your next tuner to use the double stoic setup and dial the air models in correctly and then even if the torque model isn't right, you'll just need to add a little to it to get it right... The tune scaled the way it was is your whole issue to begin with
    ~Greg Huggins~
  5. #125
    I have a new tune written with the double stoich method. I believe the injector data should plugged in at 58.6 psi across the board. Everything else is set. Then get the MAF dialed in on the dyno.
  6. #126
    Tuning Addict
    6,795
    If you have a boost referenced regulator then yes - also set your offset vs pressure vs ignition voltage the same across the board if this is the case... You'll need to dial in your MAF and VE again for this as well...
    To clarify - half IFR, double stoic, half IVT terms - ones with actual numbers - not the 1's table, x.6 instrument cluster - the initial basic settings for this...
    ~Greg Huggins~
  7. #127
    I will finish it up tonight seeing how I am not working and get in the dyno this week. I already checked the new tune on the car and it starts and idles good but my wide band has been going offline so I need to get that working as well
  8. #128
    New tune is done. Got the wide band fixed. Car idles good and is right at 1.0 lamba. Now I need to add some formulas to the scanner to correct comanded fuel. I am going to try to get it tuned for part throttle today and wot when I get to the dyno. Looks like the MAF was scaled by around 15% or so
  9. #129
    Tuning Addict
    6,795
    This is Jslic's formula, but it corrects for everything as long as your logging everything you need to... You have to log a wideband, ethanol percent, eq ratio commanded but I think that was it... Or just log lambda error - it's all the same - this one just logs afr error... Make sure your logging your channels wideband in air fuel too...
    100*(([50120]*((1-(([82.156]/2.45)/100))*14.68)) - ([50118.238]*((1-(([82.156]/2.45)/100))*14.68))) / ([50118.238]*((1-(([82.156]/2.45)/100))*14.68))
    ~Greg Huggins~
  10. #130
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by dwright122 View Post
    What the guy is saying makes sense I think. I took the torque numbers form a dyno sheet, and that should work too.
    I agree with Huggins..... scaling the tune would throw everything off, while the double stoich method works perfectly and keeps things in line.
    Looks like you are on the right track....
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  11. #131
    Okay, I got my tuner back since upgrading to the pro version, I have the car tuned for part throttle but am having little trouble how to set up the camanded afr as I am using double the stoich method and ARF error, I am trying to tune in lamba, I put the above formula in but not sure if I have it correct. below is a log file showing my layout. any help would be appreciated
    part throttle.hpl
  12. #132
    I think I am close, after trying a few more things attached is my WOT log, II believe the AR error needs to be x.5 due to the x2 stoich method. question is can I just plug it into excel. x the values by .5 and them multiply by % into me MAFvs Freq. the Commanded and what the AEM wideband are reading do match almost exact but seems to be a little rich
  13. #133
    Jun 2011
    Montreal, Canada
    758
    Using lambda you should have to do that.
    Alky Control Meth,
    ARH 1 7/8 headers,
  14. #134
    Quote Originally Posted by realcanuk View Post
    I didn?t think so either but for some reason there is nothing showing in the lamba eq graph. It?s not showing any difference in percentages
  15. #135
    Jun 2011
    Montreal, Canada
    758
    I cant see how you have it setup. It defaults to my setup when I open your scan. You must have something missing in either the channel list or graphs layout.
    Alky Control Meth,
    ARH 1 7/8 headers,
  16. #136
    Jun 2011
    Montreal, Canada
    758
    MAF - lambda error....
    Alky Control Meth,
    ARH 1 7/8 headers,
  17. #137
    I maybe but I can?t find any templates to review so I may be off. I know my commanded afr match my actual so I can?t be too far off but can?t figure out that one lamba eq. Graph
  18. #138
    It?s entered exactly like the above pic and there is no data filling the cells
  19. #139
    Jun 2011
    Montreal, Canada
    758
    make sure "equivalence ratio commanded" is in the channel list ???
    Alky Control Meth,
    ARH 1 7/8 headers,
  20. #140
    Jun 2011
    Montreal, Canada
    758
    Alky Control Meth,
    ARH 1 7/8 headers,
