Results 1 to 7 of 7
Thread: Flex Fuel Kit
    Dec 2016
    Raleigh, NC
    127
    Flex Fuel Kit
    Can someone help me with installing a ethanol sensor onto my 2008 Silverado 5.3l.
    I have a sensor and harness in mind but I'm not exactly sure they will work.
    https://www.summitracing.com/parts/nal-13577429
    https://www.summitracing.com/parts/nal-13352241
    If these will work then what pin on the computer do I need to wire it to...
    If anyone has done this and wired there's up correctly please help me out!
    Jan 2014
    Australia
    1,544
    may be a bolt in kit for u here https://dsxtuning.com/collections/flex-fuel-kits
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,801
    My TBSS kit will work.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2016
    Raleigh, NC
    127
    Yes I could use one of those but I'd like to take the cheapest route possible. Plus I still don't know which pin I need to run the wire to.
    Aug 2012
    SV, AZ
    447
    Quote Originally Posted by johnny_boii View Post
    If you buy the kit you get the support of the vendor selling it. Dave will take care of you. The cheapest route is rarely the best route.
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    763
    Glanzer Performance have some flex fuel kits, just got mine from there..... nice and simple. Couldn't get mine from another place wanted to charge a fortune for postage to Australia.
    2017 Toyota Kluger - 10.1" Android Custom Head Unit, Rockford Fosgate Speakers, 85kg Roof Racks. Prev: 2009 Cammed VE SS Sedan, DOD Delete, 210/218 550', RAMJet OTR, HiFlowCats, IQ System, Amp/Speakers.
    Aug 2016
    Texas
    222
    J1 Connector, Pin #40. Right next to the yellow wire for the MAF. This is the basic setup I used.
    http://paceperformance.com/i-2237349...ensor-kit.html
    This kit contains the following.
    13577429 E85 Sensor
    13352241 Wiring Harness
    13575575 Wire and Pin connector
    RUS644123 (X2) Russel quick connect 3/8 in. to -6AN fillings.
    Be careful when adding the pin in the J1 connector. It is very easy to bend/twist/loosen/break wires or otherwise ruin connections. I found out the hard way.
