Guys, please help.. customer brought in a motor swapped mustang with a 2015 coyote and FRPP. Car runs great, transistions nicely, starts perfectly, maf transfer is excellent, even at wot. Problem is fuel source will not change from CL stoich. Can anyone see what is done wrong in this file? I found that the top clutch switch is not installed, not even sure about the bottom one being done right, but the clutch position says 0% which I assume is correct? Attached is the file. Thanks in adavancefoxbody 50 procharged tune.hpt
