Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: 2015 FRPP will NOT enter PE.
  1. #21
    Jan 2013
    Hawaii
    2,101
    I would have expected to see more than 32 LB/min peak in a pro charged coyote. another 1000RPMS and youd be at the max of your MAF curve. I think your SD changes are causing you to tune your MAF curve wrong. With your MAF that far off your torque values and load values would be too. That or you have your MAF in a very small pipe.
    MAP max delta above BP, you are over twice what you really see. calculated MAP max you are about a third too high. MAX load is too high. Load at WOT is stock(about half of max load). These things can cause your MAF value to be wrong when the cylair filter is enabled.
    Then you have OP enrichment required disabled under your VCT. This basically makes fuel enrichment based on pedal position and desired torque for load, which you are probably around half or less of what you should be from the MAF values you are seeing.
    I'm surprised lowering your max torque values did anything at all.
  2. #22
    Dec 2005
    222
    I'm with Murfie here. At 3500-ish rpm you're at u=102-ish on the MAF. The 32lb/min is probably ballpark, but you're close to exceeding the MAF limit. Minimum I'd recommend double checking your injector modeling then look into that MAF. May be that the MAF is in just too small a section of piping.
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
  3. #23
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    I did have a question, I see in an earlier reply that some were having issues of the commanded lambda being different from the actual measured lambda. I'm having the same concern, however the fuel trims are getting the actual lambda to where it is being commanded in the tune, although the "commanded lambda" in the scanner shows differently. I'm assuming this is a glitch?
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
  4. #24
    Feb 2019
    Texas
    304
    100% what murfie said, had the exact same issue with a 2016 Procharger stage 2 car. I was chasing my tail for like 3 days straight then put everything back to base and dialed in the maf and that took care of the car not going into PE. depending on your pulley setup you should be flowing between 60-80 lb/min through the maf around redline (remember prochargers have pretty linear power curves). Everything he listed has to be spot on, meaning within a small margin of error.
    ?Our greatest success comes from failure? -Confucius
  5. #25
    Senior Tuner metroplex's Avatar
    Apr 2013
    Detroit, MI
    1,077
    Quote Originally Posted by 96gt4.6 View Post
    I have the same problem... Commanded lambda is 1.2-1.3 and actual is 0.82 (what I desired/wanted).
