Results 1 to 6 of 6
Thread: 2000 GTP VE Tuning problems
    Advanced Tuner coachcrow56's Avatar
    Dec 2004
    Longview, Texas
    305
    After putting a rebuilt engine in my car, I am attempting a VE tune with my LC-1 wideband. VE AFR error is working fine, but when I set the MAF Fail High to zero in Engine Diagnostics, and set Closed Loop temp to 284, the car will not run. I have multiplied the VE table by 1.15 to richen the values, and it will not continue running. Any suggestions? Anyone have a modified VE table for a 2000 GTP that I can look at?
    2.8/3.0/3.2 Pulley/ZZP CAI/1.6 HS Rockers/Hi Energy Comp Cam 76-802-9/LS7 Lifters/ZZP Stage 2 Intercooler/TOG Headers/Triple Edge Performance Stage 3 Transmission/3.29 Ratio/NGK TR6ix IRIDIUM .40 GAP/ZZP Fuel Rails/ZEX 100 shot NOS/GMPP Sway Bars/KYB Adjustable Struts/Power Stop Performance Pads/Rotors
    13,559
    Just unplug the MAF, the IAT is not connected in the MAF harness so it's easier this way.
    You'll likely have to pedal the car to life to make it run off the VE table.
    Dec 2004
    Longview, Texas
    305
    I have tried pedaling it, and it will try to idle but rpm's roll from 1000 to less than 400 and it dies when I put it in gear every time. I bumped up the idle in VCM controls and it still dies when I put it in gear.
    Advanced Tuner IARLLC's Avatar
    Aug 2016
    942
    I second 5FDP's advice. No need to set the MAF Fail High to zero on these. You just unplug the MAF on these.
    Sep 2017
    1
    i was just doing this last night...i had to add another 15% to the ve table and pedal it for a little bit to get it to stay running...didn't notice till i got back from a drive that it didn't stay in open loop like you would think...
    guess i'll go unplug the maf and try again
    Feb 2014
    27
    It is possible that you car is set to run off alpha n tables and not use the ve table at all my car is a 2000 grand prix GTP and I run in open loop and no maf 24/7 car runs perfectly fine year round there is lots that needs to be changed but it can be done also hptuners doesn't have a few tables witch help out lots if you own a 3800 powered car and are not use ing The Tiny Tuner and Hptuners together or dhp power tuner and The Tiny Tuner together then your missing out The Tiny Tuner is open soure and hass lots of extras we need a New Tiny Tuner Group to finish what was started I've tested lots of tables in tiny tuner bit still lots to test very good editor
