Originally Posted by
Amille28
thanks. Do you know if in addition to the CANBUS a/c request signal if i would need to hook up a pressure sensor to the E38
Here is my understanding of what the E38 does.
1. waits for a/c demand (snowflake a/c button to be turned on) on the CANBUS
2. monitors pressure on the hi side and controls fans when a/c is on this in cludes a ground wire, 5v reference and differential pressure signal wire
3. puts a ground to the a/c relay to activate compressor voltage and takes it away when either the a/c demand goes to OFF or the RPM cutoff is reached.
Do I have it right?
