Results 1 to 8 of 8
Thread: 03 Silverado P59 12579405 Manual Segment Swap
    Aug 2017
    16
    really looking for a segment compatible os for this truck looked up every possible combination of vehicles in repo help please
    13,578
    Couldn't find one either.
    But you don't have to have one. You can still disabled all the transmission related DTC's and all the abuse functions to make the motor run.
    Aug 2017
    16
    Thanks alot man what are the side effects of doing it that way as opposed to a segment swap started my swap tonight heres some pics
    13,578
    For some not having it know if it's park or drive or in gear could be trouble some but you could work around that. Ideally you'll still want to wire in something to make the speedo work, can be very helpful sometimes.
    The last one I worked on, we swapped a TH350 behind a 5.3 in a rockcrawler. I just disabled everything I didn't need for the transmission and abuse tables and it works great.
    Aug 2017
    16
    Thanks a lot man man, what would be the best way to simulate d/p ?
