Results 1 to 4 of 4
Thread: GPS and ODBII
    Aug 2017
    2
    GPS and ODBII
    Can I use both Bluetooth ODBII and Bluetooth external GPS with Track Addict on an iPhone? (If this has been discussed, then my searching skills have failed me and I apologize)
    HPT Employee Weston@HPTuners's Avatar
    Jul 2014
    39.735034, -103.894459
    868
    Yes, as long as both Bluetooth devices are compatible with TrackAddict, they can be used at the same time. Please note that our iOS and Android versions have different hardware compatibility due to differences between these platforms.
    Generally, Bluetooth allows for multiple simultaneous connections, whereas WiFi devices (used for external camera control and some OBD-II devices) are limited to one at a time because your device can only connect to one WiFi network at a time.
    Aug 2017
    2
    Quote Originally Posted by Weston@HPTuners View Post
    Is it pretty easy to setup one time, or do you have to mess with getting the blue tooth connections up while you should be on the track In other words how much fussing around can I expect from this setup while I am at the track?
    Thank you for the info!
    Jul 2014
    868
    I would definitely test it all once before you're needing to go on track, but the Bluetooth connections are generally easy and automatic after you have set them up the first time. The supported BLE OBD-II devices on iOS (PLX Kiwi 3 and Carista) are super simple once you've put the app's OBD option into "BLE" mode, and other supported Bluetooth devices should work easily too but will need you to pair them the first time via the iOS Settings app.
