Thanks for posting this Jay
Don't forget about the spark modifier tables (Hot/Cold IAT and Hot/Cold ECT) and the WOT Lockpin table (assuming your cam may get to the lockpin position at some point).
Specializing in building and tuning 1000hp, daily driven, 9 second cars!
www.ostdyno.com Shop Phone: 724-368-9000
anyone have a tune to get me started: I have full lenth headers and exhaust,its a police package 2009 charger, eagle 5.7 hemi, im getting a o2 code id like something with trans stuff maybe also ,then I can compare to my factory and see what you did to help car and learn from there......Jay
Great thread!
This is a good thread. On the spark setting discussion.....surely it's not still common practice to decrease sensitivity of the knock sensors by 50 to 100%? That doesn't sound right to me. Have things changed since those posts in this thread?
I've always been told to leave the knock sensors a lone, tune the car on the daily fuel (in my case 93) and log. See where STKR occurs and note it. Then add octane (race gas) and re-test to see if knock remains. If it does, THEN you adjust the sensitivity only on the areas affected.
It depends on the car. As a "general" rule Dodge knock sensors are more sensitive than GM and Fords. The knock sensors are on a 5v scale, and if you look at the stock thresholds they are pretty low.
I usually watch the knock sensor voltages and see what they are doing when the PCM "thinks" it's knocking. If they are showing like 1.5 volts and the thresholds are stock, more than likely it's not knocking. If its showing 2.5+ volts there's a good possibility it is knocking.
You can pull some timing out in that area and see what it does or as you mentioned put higher octane fuel in it.
I'm poking around in the stock tune and just trying to figure this stuff out on a stock Scat. My first attempt at anything will probably to be to tune for larger injectors without changing anything else.
The power enrichment commanded afr tables don't make a lot of sense to me.
Why bother with pratio or aircharge axis of the table if it's not going to effect the data as it changes? Seems pretty damn odd.
And isn't aircharge a result of pratio? And lastly, if you're actually in PE, most of the area at the top of the pratio table will never happen. If the throttle blade is open (to envoke PE), pratio is pretty close to 1 immediately.
Any input on how these two tables work together or when each is used?
For reference, here at the tables for this car:commandedafr.jpg
I'm sure they build the full table to be sure they cover any scenario that "might" occur.
In looking at hellcat tables, I notice they do use the lower right portion of the tabel more under pratio. I guess the table has to cover all applications....
This is some good info! Its defiantly a learning experience!
Jay,
Thanks for providing all of the injector scaling info. This is by far one of the most critical aspects to tuning ANN. Most appreciated.
I just wanted to point something out. If MDS is active on your engine (and not disabled) while you're doing your logging, you may want to use Fuel Mass for one of the cylinders that's not deactivating. The cylinders that deactivate on the Hemi engines are 1, 4, 6, and 7.
If you are working on a Hellcat or a manual trans Challenger, you can ignore this.
If you are removing spark from areas that knock and have knock reoccur in the same area again, don't forget that knock is learned in the pcm on these hemi's and should be cleared between flashes, it's adaptive learning. It'll prevent you from the headache.
