Results 1 to 9 of 9
Thread: 6HP26 WOT Shift RPM
    Jun 2007
    Melbourne Australia
    98
    6HP26 WOT Shift RPM
    I've got a 6 speed auto ZF 6HP26. In the auto shift speed it has 1-50 shift patterns. Which ones do I alter to increase 1-2, 2-3 and 3-4 shift wot rpm values?
    Nov 2009
    AUSTRALIA
    104
    Pretty sure in the tune repository there is a file with a modded zf tune ( i think by a trans shop) that you cuold compare or veiw to get an understanding on what tables are being modded for those shift points.
    Nov 2009
    AUSTRALIA
    104
    Pretty sure in the tune repository there is a file with a modded zf tune ( i think by a trans shop) that you could compare or view to get an understanding on what tables are being modded for those shift points.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Baddy, mind posting your file, stock or otherwise, you'll tend to get more assistance when you provide more info mainly the .hpt file in question.
    Jun 2007
    Melbourne Australia
    98
    Refer attached tune file, appreciate the assistance.
    Mar 2015
    26
    Quote Originally Posted by Baddy View Post
    I do not have my laptop with me so bear with me.
    Table 27 is Manual mode, Drive/Perf is spread out over the tables 1-26 and 28 through to around 36 or so from memory... you will have fun working out what is what from there, I have made holistic changes to prevent kickdowns, but most of my work is done in manual mode so I haven't bothered much with it
    The number in these fields is OSS, so to alter your 1-2 shift point you take the throttle position you want to make the change at (WOT is generally the 98.9% and up fields, 100.4 is kickdown) and in the cell/s under 1-2 you take that number and multiply it by 4.17 (first gear ratio) and you come up with an ISS which while close to engine rpm does not take converter slip or clutch slip (just hope you dont have the latter) into account. This is the Input shaft speed that the transmission anticipate the shift. If the number is 1400 then the ISS shift point is 5838rpm. If the converter has 20 rpm slip when locked up then the engine will be at 5858. If the converter still has 600rpm slip then it will be 6438 engine rpm. You cannot predict this amount of slip as it varies with power levels as the PCM has a slip threshold that nobody has been able to decipher and therefore control.
    Daniel
    Jun 2007
    Melbourne Australia
    98
    Quote Originally Posted by CAT600 View Post
    Daniel
    Ok great I'll check it out! What is the 2nd and 3rd gear ratio so I can multiply that too?
    Nov 2009
    AUSTRALIA
    104
    Thanks for sharing Daniel,
    Baddy 2nd is 2.34 and 3rd is 1.521, let us know how you go.
    Dec 2017
    1
    Quote Originally Posted by JVK View Post
    Hey mate, couldn't find the file for the modded zf tune, you mind posting the link of that thread here? Cheers
