Hey yall, came here as my last hope, maybe someone can help me with my pick up.
Specs:
6.2L l9h 78mm Turbo 5psi
60# Injectors
340LPH Fuel Pump
PMAS MAF
genIV E38
Issue:
Had my truck up and running good after the turbo install and dyno tune. Well replaced my trans and Fuel control module. Had my buddy over at gm, program the fuel module, and accidentally flashed my tune with the stock file.
I purchased HPtuners, and ive been reading for the past couple of months before the big purchase. I tuned and got some practice on my other pick-up truck and cammed camaro, but dont consider myself fluent or a tuner.
For some reason, my truck just will not start. I turn the key itll crank and maybe turn on & itll immediately die, i unplugged the MAF and it actually turned on for a few seconds longer. I get a raw gasoline smell when im cranking too. I have a tech 2 and diagnosed all the modules. Checks plugs/packs/wires ect. Im about to give up on it, and i really dont want to.
Does some one have an open loop tune close to my specs that I can flash over, to make sure its not a mechanical/sensor issue, and perhaps just a tuning issue.
I can pay for your time, i dont mind, i would like to get this fixed before im off for deployment, and maybe even get a decent tune in it.
-Thank You
