Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: LC-1 Wideband WTF
    Señor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    LC-1 Wideband WTF
    I already have another waiting to go in...just wondering if this is a wideband or a controller issue?
    2008 Viper - now with HPToona - 1/4 Mile Shenanigans Here
    11.02 @ 130
    Apr 2006
    573
    Quote Originally Posted by MeentSS02
    did you use the hpt provided pid or a custom one? also..that looks familiar..
    Jun 2005
    Dayton, OH
    1,132
    Custom one, but the LC-1 and HPT agree on what's what, and it was programmed for the small voltage offset I have.
    11.02 @ 130
    Apr 2006
    573
    damaged sensor?
    Jun 2005
    Dayton, OH
    1,132
    Looks like it might be a grounding issue...I'll do some messing around.
    11.02 @ 130
    Apr 2006
    573
    wasnt the issue with mine so.. good luck
    Jun 2005
    Dayton, OH
    1,132
    I'll see what happens...looks like I should be grounding the heater through the EIO as well when I'm logging, which I'm not currently doing. The output is being pulled down at random intervals, but doesn't read erratically any time else. Klattin over on Innovate's board suggested a grounding issue, so I'll go with that and go from there...
    If all else fails, I have a brand new sensor sitting on my table waiting to go in.
    11.02 @ 130
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    605
    DO NOT ground the LC-1 through the EIO. It cannot handle the current. You can ground everything BUT the heater through the EIO. If your LC-1 fails, there is a newer version that has ground fault protect built-in. Innovative will give you an RMA and replace yours if it failed.
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
    Jun 2005
    Dayton, OH
    1,132
    Hmmmmmmmmm...you say to not ground the heater through the EIO, but Innovate says to do this along with Mr. soundengineer. Which one is it?
    BTW, I tried grounding the heater along with the other grounds through the EIO (the heater is in either pin 5 or 6, the others go through the other one), and it helped some, but it is still doing it.
    Any other thoughts?
    11.02 @ 130
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    DO NOT GROUND HEATER TO EIO!!!!
    heater to chassis or cig lighter plug(which is what I do)
    looks like a grounding issue
    -Scott -
    Jun 2005
    Dayton, OH
    1,132
    Sunuvabitch...I'll make sure that gets fixed ASAP. I only ran it like that for 45 seconds, so I think I'll be fine.
    I seriously don't know how else I could do my grounds to make this problem go away. Geez this is annoying.
    11.02 @ 130
    Apr 2005
    4,387
    I use the Cigarette lighter for heater power(red wire) and hreater ground (blue wire)
    then run your other grounds(white, green, calibration button,LED wire) to the EIO ground
    nuff said....
    if you stil have isues then talk to innovate about an RMA and get a new one...
    or come to KC and I'll show you how to make it work..LOL
    or try to catch m eout on tour in some city close to you..LOL
    -Scott -
    Jun 2005
    Dayton, OH
    1,132
    That's my plan for now...I'm actually gonna ground everything but the heater wire to the OBDII ground (since I run this wideband full time), and the heater is just gonna go to a chassis ground somewhere (maybe even the cig. lighter). For some reason, I think grounding to the passenger side head just isn't working...
    11.02 @ 130
    Apr 2005
    4,387
    thh engine is metal..but its aluminum..and aluminum isnt the greatest conductor...its good..but not as good as it should be...
    try going to the chassis or even straight to the battey negative terminal...
    -Scott -
    Jun 2005
    Dayton, OH
    1,132
    Hmmmmmmmm...battery negative terminal you say...that could actually be done fairly easily...
    11.02 @ 130
    Apr 2005
    4,387
    I still vote for the bolt that holds down the seat myself....
    I use that to ground my power inverter so I can charge the laptop in the car
    -Scott -
    Jul 2004
    1,579
    Steve, don't worry about it and use a filter. My AEM does that when I log less then 7 PIDs. Once I log more then that, the resolution will "filter" it out. I verified this by logging the raw voltage and sometimes would get 0V (10.00 AFR), so I made the filter and my tunes come out great.
    Jun 2005
    Dayton, OH
    1,132
    Actually, that's exactly what I did...but now I did all that rewiring That makes Nana sad
    Thanks for sharing the experience though...
    11.02 @ 130
    Sep 2002
    Chicago, IL
    6,395
    Those spikes look like dropped frames.
    .12 takes care of this.
    We got this guy Not Sure, ...
    Jun 2005
    Dayton, OH
    1,132
    Really? Any chance of getting that Beta to see if that works?
    11.02 @ 130
