I see that the values are base upon a percentage and that slope the percentage up as temperature rises. I am trying to get the car to run cooler with the lower stat installed. Right now there is no value in the 192 and 196 column. At 225, where the car seems to start going back down in temp there is a 90%. Is there some kind of time frame that the fans stay on at 90% that brings the temps back to 192?
Why wouldn't I just use 90's in the 192/196 column and keep the temps as low as I can with a stat installed?
