Hey everybody, I'm going to be converting over to e85 for my 11 Mustang GT. I think I understand all the steps needed but wanted to clarify. I will also be installing the FRPP 47# injectors. The car is NA so no power adders. I do have LT Headers, Cobra Jet IM, Cobrat Jet Mono TB.
These are my plans:
Change stoich to 9.86
Copy the injector data from the stock Roush TVS tune (should be the same injectors?)
I will drain the gas out and replace with E85.
To dial in spark, I normally run about 26 at WOT. with all advance and retard 0'd out So I will start at 28 at WOT and enable advance and retard. After datalogging I will see what spark advance the ECU goes to and then set that for spark and datalog again.
Clean up any MAF data if it's off.
Anything else I might be missing on this?
Thanks!
