EFI Tuning LLC
Tuning Tool: HP Tuners v3.2.x
Platform: 2016 Camaro SS
File: 2016_ss_flex_fuel_baseline.hpt
Changes:
*** required ***
- modified Engine -> Fuel -> General -> Air Fuel Ratio -> Stoich AFR-> Flex Fuel AFRs
- modified Engine -> Fuel -> Open & Closed Loop -> Flex Fuel -> Flex Fuel -> Enabled
- modified Engine -> Fuel -> Open & Closed Loop -> Flex Fuel -> Flex Fuel -> Fuel Sensor -> Sensor
- modified Engine Diag -> DTC's -> P0178 -> Flexible Fuel Sensor Circuit Low -> checked, Error Mode -> MIL on Second Error
- modified Engine Diag -> DTC's -> P0179 -> Flexible Fuel Sensor Circuit Low -> checked, Error Mode -> MIL on Second Error
- modified Fuel Sys -> Diagnostics -> Flex Fuel -> Sensor Diag -> Enable
*** optional ***
- modified Engine -> Spark -> Advance -> Spark Correction -> AFR Correction -> Alcohol -> Gas table
- modified Engine -> Spark -> Advance -> Spark Correction -> IAT Spark -> Mult4 -> [1.00 1.00 0.80 0.50 0.20]
- modified Engine -> Spark -> Advance -> General -> Cranking/Start -> Cranking -> enhanced for Flex Fuel
- modified Engine -> Spark -> Advance -> General -> Cranking/Start -> Alcohol Adder -> timing added for Flex Fuel cold starts
